Samsung camcorder cable
mleeis
Hi all first post from me .
I want to connect my samsung wp-90
8mm camcorder to my tv to view , the lead it came with only has a yellow & red connector no red !!! I can hear once it’s connected via the tv but no pictures… Do i need to get the cable that has the red as well or do i need a different cable all together? Many thanks mick
noiseboy72
The yellow connector is video and the red and / white connector is audio. Some camcorders only had mono audio, so only had 1 sound connection.
Does your TV have a phono connection for video? Some newer ones do not, or require an adapter cable to be plugged in.
mleeis
mleeis
Thanks for your reply appreciate it . No idea i have added a photo of the rear of tv . Has those 3 coloured inputs but i only have yellow & white on my av cable
noiseboy72
Connect the yellow wire to the top socket and white wire to the middle socket.
This should then work correctly.
