Samsung BPD-1400 & 7.1 tracks
eddytrouble
You guys,
I got a Samsung BPD-1400, just upgraded to latest firmware. I got a few questions.
I am going to buy an Home Theatre system, and will get receiver and speakers separately. My budget for the Receiver is £150-£250.
My initial idea was to invest the cash in a really good 5.1 receiver, as there aren't many movies with 7.1 soundtracks. Furthermore all Dolby TrueHD soundtracks seem to still be 5.1. Then I noticed that there's many DTS-HD MA soundtracks which do play in 7.1, actually.
My questions then are: my player decodes Dolby True HD, but is it only via HDMI bitstream, or can it actually decode itself? In that case I could connect each channel to the Receiver analogically, and that would be it. I know it decodes DTS-HD MA as well, with the latest firmware, but is it only bitstream or is it actual decoding, that I can then use with analogical connections?
Basically my choices are:
1. Get a really good 5.1 receiver, and connect analogically to the Blu-ray player, and get Dolby TrueHD 5.1 soundtracks fine. That is if my Blu-ray player decodes Dolby True HD internally.
2. Get an ONKYO TX-SR506 B, which supports 7.1, and connect analogically to the Blu-ray player. Provided my player actually decodes DTS-HD MA, then I would get 7.1 sountracks correctly. Cause this Receiver won't decode DTS-HD MA bitstream, correct?
3. In case that my Blu-ray player only sends DTS-HD MA bitstream, is there a good receiver around which decodes it, and that I could use?
If my questions made any sense at all, could you please reply? ;)
Eddy
kingfats
My questions then are: my player decodes Dolby True HD, but is it only via HDMI bitstream, or can it actually decode itself? ?
Eddy
Hi eddytrouble. :)
The 1400 can internally decode TrueHD no problem. :smashin:
All the best.
