Samsung BDP1400 bitstream not working
Discussion in 'Blu-ray & DVD Players & Recorders' started by dzbdog, Feb 10, 2009.
  1. dzbdog
    dzbdog
    Feb 10, 2009
    Hi all,
    I'm new to to the forums here but have been lurking about for a few months. I have a Samsung BDP1400 with the latest firmware v2 installed and hooked up to a Pioneer VSX-LX50 receiver.
    Here is the problem: I set the BR to bitstream and then insert a BRD that has TrueHd (IronMan) and then go about starting the movie. I hear sound at the very start ie menu but once I start the movie I get no sound or indication that the movie is in TrueHD, the movie is playing but no sound. I can play the movie fine in PCM with sound but once bitstream is on, no sound. I have tried a few other movies and the same is happening. I have checked all cables as well and the are in the right place.
    Any help would be appreciated.
    TIA Dave
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Welcome to the forum. :smashin:
    That is odd :( have you any discs with DTS-MA tracks at all?
  3. dzbdog
    dzbdog
    Feb 10, 2009
    I just tried "The Incredible Hulk" with Ed Norton and no sound. I set the BRP to bitstream with PCM down conversion off. I hear sound at the menu but nothing once I started it. I'm wondering if I have a lemon player
  4. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Your HDMI for audio is that correct?
  5. dzbdog
    dzbdog
    Feb 10, 2009
    Not too sure what you mean by HDMI for Audio?
  6. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    HDMI cable from 1400 to the Pioneer amp? :)
  7. dzbdog
    dzbdog
    Feb 10, 2009
    Hello,
    ah, yes I have a HDMI cable from the 1400 to the Amp then from Amp to TV. I just went to check the cable from 1400 to amp and tried it in HDMI in 2 and the same still happens no sound.
  8. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Ok,bitstream is the correct setting and once chosen TrueHD "should" show on the amp,does DD or DTS light up on the LX50 with regular DVD via the 1400?
  9. dzbdog
    dzbdog
    Feb 10, 2009
    The TrueHd does not show up on the amp when but when playing a normal dvd DD does show up.
  10. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Maybe a setting on the amp? I would ask in the Pioneer forum as well.
