Samsung BD-H6500 3D Blu-ray Player picture problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Sorin, Oct 18, 2015.
  1. Sorin
    Sorin
    Oct 17, 2015
    4
    Dublin
    Hi, i recently bought a Samsung BD-H6500 3D Blu-ray Player, everything works perfectly but on some movies the picture is just horrible, it's not clear at all does anybody else has the same problem and how can I fix it
  2. skk3
    skk3
    Sep 16, 2005
    2,542
    Rushden, Northamptonshire
    +245
    DVDs, Blu-rays or both? What are the symptoms?
  3. Sorin
    Sorin
    Oct 17, 2015
    4
    Dublin
    I've only tried with blu rays, the picture is just horrible the pixels are big, it's the kind of picture you'll get from a vhs not a blu ray
  4. Sorin
    Sorin
    Oct 17, 2015
    4
    Dublin
    That's how bad the picture is
  5. ArmitageShanks
    ArmitageShanks
    Feb 19, 2010
    2,315
    116
    +667
    Hmmm....not sure, but on my F6500 I found that having "BD-Wise" active messed up the resolution for non-BD content (BDs played perfectly though).
    Try disabling BD-Wise, and force the output format to always be 1080p, with 24p content set to automatic (from what I can remember). That gave me consistent (and excellent) results across the board, but it might depend on your TV.
  6. Sorin
    Sorin
    Oct 17, 2015
    4
    Dublin
    It's not the tv and I tried to change the bd-wide as well and no success
  7. skk3
    skk3
    Sep 16, 2005
    2,542
    +245
    Check all resolution settings and maybe perform auto set up again...
