Samsung B8000/B8050 worth it over B7000?
Discussion in 'Samsung TVs Forum' started by Shadowsoul, Jun 10, 2009.
Tags:
  1. Shadowsoul
    Shadowsoul
    Jun 25, 2008
    16
    Hello everyone, I am just about to lay my hands on a new TV and have been looking at the B7020 for quite some time now.
    However the B8050 had to show up and make it hard for me, so i have a simple question:
    Does anyone know how they compare to eachother for picture quality?
    From what i understand the 8000 would have slightly (much?) better interpolation and responsetimes, as well as a theoretical higher dynamic contrast.
    The problem for me (in Sweden) is that the 8000 is about 25% more expensive, which ups the cost quite a bit when you consider that the 7000 costs just above £2000.
    All input is deeply appreciated!
    /Linus
  2. steveo 79
    steveo 79
    Jun 2, 2009
    107
    +4
    The 8000 has a refresh rate of 200hz compared to the 100hz of the 7000 so if your watch a lot of fast action then it should be better, the reviews of it are good but still has a bit of issue with backlight bleed on the realy dark pictures.
    Im not sure as to what other improvements there are over the 7000 tho?
  3. The_Zizzler
    The_Zizzler
    May 1, 2008
    485
    Birmingham
    +24
    Where did you hear it has backlight bleed on really dark pictures please?
  4. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    most lcds suffer from some back light bleed and these new led lit tvs can show this problem. I have the 7 series and when showing a a realy dark image you can notice a bot of clouding. However i have played about with the settings and i can hardly notice it and in normal viewing you dont even notice it.
    I love my 7 series tv and i dont think the 8 series is worth paying an extra 25%for. As for the 200hz i feel you will hardly use it, i have the 100hz set at the lowest setting and i am happy with that.
  5. steveo 79
    steveo 79
    Jun 2, 2009
    107
    +4
    ah sorry my mistake, what i meant was patchiness, thought that was classed as backlight bleed as the its extra light bleeding through, didnt realise it just meant at the edges:oops:
  6. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    yes its patches of white light you can see on a dark screen, you could also see this on most lcd screens, my tv does have this problem, however after i calibrated the tv you can hardly see it and i dont even notice it when watching movies etc.
