Hope fully this is the right place to ask.
I have a Samsung AU9000 + Optical to RCA converter(USB powered) + Powered Subwoofer + External Speakers.
I would like to know if someone has gotten this to work.
My amplifier is not working properly so I removed it from my setup.
EDIT: Removed some outdated info, removed my silly idea, added new info.
Does anyone know if and how I can get the external speakers to play sound rather than the TV Speakers?
Current setup: TV Optical port-> Optical to RCA converter-> Powered Subwoofer-> External speakers.
NEW info: I went out and bought a usb powered optical to rca converter.
From optical on TV to converter, from converter to L+R RCA ports on Subwoofer, from Speaker outputs on Subwoofer to External Speakers.
I swapped the settings in Sound menu on the TV, between TV Speakers and Optical.
On Optical I got bass but nothing from the external speakers or TV Speakers.
On TV Speakers, the Subwoofer is working but no sound from the External Speakers, only from the TV Speakers.
I havent tried swapping between manual and automatic power on the subwoofer(its a small switch) before playing music. Ill try that and report back tommorrow.
The Subwoofer is a KEF PSW 2000 - 1x Red RCA + 1x White RCA Line Input ports and 1x Red + 1x White High pass outputs. No optical port on the sub
1x Pair Speaker Output screw-down terminals output and 1x Pair Speaker Input which has the same terminal as the Output terminals.
Please see the picture.
Any help or advice would be greatly appreciated.
