Samsung Anynet+ keeps switching on the TV
Discussion in 'General TV Discussions Forum' started by tony1966, Feb 15, 2014.
  1. tony1966
    tony1966
    Feb 15, 2014
    4
    Hi all
    Does anyone know how i can disable this anynet+.
    Every time i turn on another box connected to my HDMI 2 its turns the TV on to HDMI2.
    This HDMI 2 box is being watched in another room.
    I just need the main TV to be set permanantly to HDMI 1 unless i use the sourse button to change.
    thanks in advance.
    Regards
    Tony1966
  2. tman
    tman
    Jul 16, 2002
    1,111
    Hampshire, UK
    +197
    Just disable AnyNet+. It's also known as HDMI-CEC, so obviously whatever's connected to HDMI2 is sending a signal to the TV when it's powered on to switch the TV on and change input to HDMI2. I use AnyNet+, and it works great. It also works when you power off the TV as well (other CEC devices should also power off).
  3. tony1966
    tony1966
    Feb 15, 2014
    4
  4. tony1966
    tony1966
    Feb 15, 2014
    4
    Samsung UE46F6500
    i don't seem to have the option of turning anynet off as far as i can see.
    Tony
  5. zed0
    zed0
    Dec 14, 2005
    215
    London
    +38
    I'm pretty sure you can switch off anynet+ on your model.
    I have the D6900 and I was recently playing with the anynet settings.
    From the manual for my model:
    Setting Up Anynet+
    MENU→ System → Anynet+ (HDMI-CEC) → ENTER
    ■■ Anynet+ (HDMI-CEC) (Off / On)
    To use the Anynet+ Function, Anynet+ (HDMI-CEC) must be set to On.
    Should be similar menu options on yours.
  6. tony1966
    tony1966
    Feb 15, 2014
    4
    Cheers Zed found it now. All working as required.
    Tony
