Samsung anynet+ issue
Discussion in 'Samsung TVs Forum' started by 1nfinite, Jan 8, 2012.
Tags:
  1. 1nfinite
    1nfinite
    Jan 8, 2012
    Hi, a friend of mine recently bought a Samsung 6100 TV & a Sony ht as5 5.1 home theater system & is having problems with Samsungs Anynet+
    Everytime he turns the TV off he has to go into menu & although it says on.. it doesn't work, so has to turn the receiver option to off then on again to reset, which you can imagine is a pain everytime he switches the TV on..
    Has anyone else had this problem with the Anynet+ before.
    If he phones Samsung they will blame Sony & Sony will blame Samsung, so hes kind of lumbered.
    I connected the system up for him & wired an hdmi from the tv to the receiver & optical as well..
    Any help to resolve the problem would be a help, maybe I should update the firmware might fix the issue.
    BTW I didnt know what area to post, as this seems a fault with the TV I posted here, although it could be a compatibility issue.
    Thanks,
    Colin.
  2. fiveaside
    fiveaside
    May 25, 2010
    128
    +25
    Don't think it would be compatibility issues. Have you checked what version hdmi cable you're using? I recall reading in my Samsung instruction book a minimum of 1.3a is required for use of the anynet feature. Have you an option in the sony to turn it on?
  3. 1nfinite
    1nfinite
    Jan 8, 2012
    Hi thanks for reply Five,
    I am using 1.4v cable as he also has a 3d blueray that came with the deal, so I know is definitely working as the 3d works running through the receiver also. Not that the 6100's 3d is that great.
    (dont think so @ switching it on)
    The receiver works, just anynet+ doesnt when turning the TV back on from standby, even tho it says on in the menu.
    Colin.
  4. 1nfinite
    1nfinite
    Jan 8, 2012
  5. 1nfinite
    1nfinite
    Jan 8, 2012
