samsung and telewest
C
charlottekustra
help got a samsung 32 lcd and telewest cable (pace model) need a code to be able to use my tv control to work only able to use control for sound and power, should be able to use control to change channels etc telewest and samsung no help, also need code to make volume on telewest control volume work tried all from cable can any one help please
mbrighton
press the cable mode key on samsung remote.
press the set button on the samsung remote.
cable mode key should be lit.
input code 043.
cable mode key should blink 3 times.
test by using the power key to turn the cable box on / off.
if above does not work then try code 042.
C
charlottekustra
tried these codes do not work pressed cable set then code then power no joy samsung say not all cable boxes work
C
charlottekustra
the remote blinks 3 times but power does not go on am i doing something wrong
mbrighton
Sorry... these codes are for the scientific atlanta tvdrive box.
which telewest box do you have?
let me know and I'll try and find the website I got the codes from.
I was pretty sure the code was four digit.
I use a Samsung, the code I used was either 0073 or 0079. Give those a go.
The 4 digit codes program the tvdrive remote to change volume on tv.
These 3 digit codes allow you to program the samsung remote to control cable box.
Found it - somewhere on this page you may find your code
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7903
C
charlottekustra
input code 043.
the model of cable box is a pace everyone seems to have this problem
C
charlottekustra
hi mbrighton thanks anyway just my luck will keep looking out for the code maybe they will come up with it sometime , does that go for all cable boxes from telewest ?
mbrighton
no -code 043 work fine for the scientific atlanta telewest tvdrive box.
can change channel, turn on/off bring up the epg etc.
can't bring up some of the menus though
so still have the telewest remote to hand:rolleyes:
A
alexanderbsmith
I take it all this refers to the current 32in Samsung LCD. I have the last but one Sammy (year old) and the remote doesn't seem to have a cable key never mind it lighting up:(
Similar threads
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
