Samsung and sky+ remote
Discussion in 'Samsung TVs Forum' started by ex sky man, Aug 31, 2005.
Tags:
  1. ex sky man
    ex sky man
    Hi all
    Just got a samsung LE32R41B lcd...Well chuffed
    But i can't get my sky+ remote to operate the volume !!!!
    It does the channels and standby but not the volume
    Ive tried nearly all codes....Any Ideas ????
  2. saurabh123456
    saurabh123456
    Try code 646
  3. ex sky man
    ex sky man
    Nope...No volume.....
  4. Godster
    Godster
    Aug 24, 2005
    94
    Tried that code with mine last night, same model.....worked fine!
  5. DU02
    DU02
    Jul 29, 2005
    81
    +4
    646 works for me too
  6. alphaomega16
    alphaomega16
    May 17, 2005
    13,268
    163
    Southend on sea
    +3,170
    How do you get to enter the codes ? is there a hidden menu in sky
  7. haydenh
    haydenh
    Well chuffed with the TV but wish I could change the sky channels with the Sky remote control.
    Sky box is in the lounge and Samsung in the bedroom,
    Had no problems setting it up on my old Tosiba.
    Any help would be appreciated.
    Best regards
    haydenh
  8. daily
    daily
  9. haydenh
    haydenh
    Still no joy, possibly because I have not got Sky +
    Must be different for Ordinary Sky.
    However thanks for your suggestion.
  10. daily
    daily
    i dont have sky + either but the above code and method on that sky pdf worked fine point the remote at the tv and also i dont have any flashing red lights but still worked
  11. haydenh
    haydenh
    088 worked for me.
    Really appreciate your help.
    Best regards
