samsung aietrack sound bar
Discussion in 'Home Cinema Speakers' started by bmyo, Aug 22, 2013.
  1. bmyo
    bmyo
    Sep 25, 2006
    7
    I need the ac adapter for the sound bar only on this system Samsung hwe551, if anyone has this system please can you look on the back of the power supply feeding the sound bar and tell me what voltage and amps it uses, also if possible the part number, help needed as tried everything else, Willam
