Samsung 950 - any views so far?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigmac1, Jul 21, 2005.
  1. bigmac1
    bigmac1
    Sep 26, 2004
    107
    London
    Received my HD950 this morning and had a bit of a play around with it. Got it plugged into my Pio 435XDE via HDMI and my first impressions are that it is okay, although I don't think it is much if any better than my Denon 2900 via component.
    I was curious to see if a budget end HDMI player could out do my Denon which was why I bought it. I was struggling to push myself into parting with the cash for a hi-end HDMI player, especially with HD-DVD upcoming. I think I will be sticking with my Denon for now to be honest.
    Played around with the HDMI settings for a while trying 576P, 720P and 1080i and none of them looked any better than the Denon to me? I think I will save up my money for HD-DVD or see what PS3 looks like for DVD playback? Oh and by the way, 950 seemed to multi region hack okay with the 945 hack.
  2. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    BigMack, where did you get yours from, these seem to be hard to get hold of from what I've seen posted on these forums...
    I'm tempted, just to give DVD-Audio and SACD a try...
  3. bigmac1
    bigmac1
    Sep 26, 2004
    107
    London
    Pre-Ordered mine from Digiuk at the end of June. They said they would be receiving stock 18th July and it arrived with me today so pretty good.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    If this is finally shipping it can't be long before the 1050 and 1150 are announced and the rumour and conjecture starts all over again...PJ :)
  5. domtheone
    domtheone
    Nov 23, 2004
    14,728
    Nottingham
    +3,501
    LOL :D
    Anyone know if there available to pre-order then :rotfl: :rotfl:
  6. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    @ bigmac1 do you what to sell it then. Looking for a toy to go with my Tosh 32WL56 LCD m8. :hiya:
    Regards Tulloch
  7. bigmac1
    bigmac1
    Sep 26, 2004
    107
    London
    Tulloch, send me a PM and we can certainly discuss :smashin:
  8. rockhard
    rockhard
    Samsung HD-950 downrezed ( 480P) on component outputs while DVI/HDMI have full HDTV upconverted output. Instructions for HDCP and region free hack also makes component upconvert full HDTV link as follows -
    http://www.videohelp.com/dvdhacks.php?dvdplayer=samsung+950&hits=50&Search=Search
    Region code hack posted by nedear88, June 26 2005:
    ********NOTICE********
    I'm not responsible for the damage/malfunction to your DVD player for using the below listed hack, use it at your own risk and be prepare that the unit may not work properly after the modification on the unit.
    I tried at my risk of damaging the DVD player but it works.
    Hacks for DVD-HD950 (Region 1)
    This required the connection the unit thru it's composite or component output (not HDMI) to TV.
    1. HDCP-Free: Requires only DVD Remote.
    2. Power On DVD player, wait until "no disk" display
    3. Press "Angle"
    4. then number on the remote "4", "3", "2", "7"
    5. TV Screen displays "HDCP Free"
    6. Press "Angle" to turn off the "HDCP Free" display
    7. Try 1 more time from step 1-6 (HDCP Free will display)
    Removing the HDCP also turn the DVD-HD950 into region free player, I tried the repeat + code trick...it doesn't work, then I tried the Angle + code and the TV screen shown "HDCP Free". I put in a Region 3 disc...it play, swap region 1 disc...it play too, owesome!
    Also...turn off HDCP will enable you to use the component with adjustable resolution to it's capabiltiy (480P, 720P, 768P & 1080i), to further utilized highest resolution with my Samsung HPR-4252 plasma TV, I connected the DVD-HD950 thru it's HDMI output to the plasma TV, it works as well as the components connection except the HDMI produce much more vivid color.
    I purchased this player thru Dell.Inc for $229 in early June, try to find coupons code from the web and it may sometimes discounted to 10-25% off + free shipping. I got this unit in 2 business day no shipping from Dell.
    The player does not have DCDI logo as shown on the DVD-HD 941, the picture quality is good...can't compare to HD broadcast from Direct TV or cable, but it's almost there.
    By switching the resolution from 480p to 720P, 1080i not a big different but only gain better details at 720p or 1080i, for folks that have HDTV this is must have in order to fully utilized the 1080i or 720p resolution format.
    I am not sure the Macrovision still enable or not since I am not planning making any dub to other sources.
    Have fun and good luck in hacking business.
  9. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    @ bigmac1 how much you after for this and what colour is it to please.
    Regards Tulloch :hiya:
  10. blackwavesid
    blackwavesid
    Oct 4, 2004
    9
    I lived with my Sammy DVD-HD745 for a few months using the DVI output into my Sagem HD-D45 and was impressed with the results. Did try the sammy's component connection once but it was very disapointing.
    Recently aquired a Toshiba SD-240E for about £30 and the component output is noticably better quality than the DVI on the samsung.
    Will be sticking with the Toshiba for now...
    Sid
  11. saw2
    saw2
    Nov 16, 2004
    23
    Got mine yesterday and set up today - a great machine for the money but
    anyone who has upgraded, like me, hoping that some of the niggles with the 945 have been sorted is going to be disappointed - the on-screen message setting problem is still there for example.
  12. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    @ bigmac1 how long is the cable please.
    Regards Tulloch
  13. bigmac1
    bigmac1
    Sep 26, 2004
    107
    London
    Tulloch, HDMI cable seems to be about 3m I would say.
  14. tulloch2003
    tulloch2003
    Mar 21, 2003
    898
    Port Talbot
    +16
    Ok cheers for info. How do we do this sale in the forum then.
    Regards Tulloch
  15. Random Hajile
    Random Hajile
    Jul 1, 2004
    553
    Nottingham
    +23
  16. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    Just placed my order for the samsung hd-950 from ebuyer never used them before hope it goes ok.
  17. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    Hi saw2
    what leads does it come with do you get a hdmi to dvi lead or hdmi to hdmi
    thanks.
  18. saw2
    saw2
    Nov 16, 2004
    23
    peahead - you get both those leads (as with the 945).
    btw, if anyone needs an HDMI-DVI cable I have a one spare unused one from my 945 - first person to pm me who wants it can have it.
  19. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    Thanks for that
  20. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    weird ebuyer has 7 instock now they only had 3 when i ordered mine
  21. saw2
    saw2
    Nov 16, 2004
    23
    The lead is going to BeStu (subject to them sending an address).
    It is 2 metres long and I have already sold the 945.
  22. MarkNorton1
    MarkNorton1
    Oct 4, 2004
    863
    3
    Wiltshire
    +95
    Was going to order mine from ebuyer today, but in the last 24 hours its gone up in price, now at £215 plus delivery!! Think I'll wait for a bit!!
  23. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    Wonder if they seen this thread
  24. lupinthe4th
    lupinthe4th
    Jun 20, 2005
    141
    +21
    I have to say I am very unimpressed with DigiUK though,after Bigmac1 ordered his in June and has received it,I preordered mine in April and there is no sign of anything from them.It is certainly the last thing I will be ordering from them,I can't believe they have had my cash for 3 months and they can't even send them out in order,pathetic! :mad:
  25. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    What digiuk did to you was unacceptable but id lay the blame with samsung in the july issue of homecinemachoice in the news section it says the samsung hd-950 will have limited distribution why i dont now.
  26. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    Is this player only available in black? I've only seen black, but that picture on eBuyer looks suspiciously silver...
    :confused: :rolleyes:
  27. Rezillo
    Rezillo
    Apr 15, 2005
    174
    +9
    See http://www.avforums.com/forums/showthread.php?t=216422&page=4
    John
  28. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    Pre-ordered mine from DigiUk in April and still not got it. Needless to say DigiUK won't be getting my money again.
  29. lupinthe4th
    lupinthe4th
    Jun 20, 2005
    141
    +21
    Thanks for that Rezillo,I had missed it.I sent an email to DigiUk yesterday to cancel my order and received a reply this morning with a similar apology.It may seem stupid to wait all this time and then cancel but I find this unforgivable.
  30. Rezillo
    Rezillo
    Apr 15, 2005
    174
    +9
    They have at least promised that mine will be sent out this week.
    Digiuk have received some praise for their customer service on usenet over the years so I'm prepared to go along with them for the time being. I don't think they've handled this situation well, though, to say the least, but it should only make a week's difference in delivery, which is not the end of the world.
    John
