Samsung 945 - 42PD5200
Discussion in 'Samsung TVs Forum' started by esrg, Sep 7, 2004.
  1. esrg
    esrg
    Is anyone thinking of getting this player in Oct (Release) to plug into a 42PD5200?
    Samsung's literature says that the player upscales std DVD to 1080i/720p and outputs in HDCP/DVI. Although I know the screen will take these resolutions (with a litle loss on 1080i), I am not sure about the HDCP side of things i.e does my hitachi accept HDCP or can the 945 output HiRes with HDCP turned off. Does anyone have the answer?
    I am getting quite excited about having HD output(nearly/kindof) for just £160. Must be too good to be true right?
  2. BoomBoom
    BoomBoom
    Search for PD5200 and DVI and you should come up with my posts which should answer your questions.
    Boom
