Samsung 8K Q950R QLED Owners and Discussion Thread
Stafford
just joined the group - i can see the convo - we'll have to wait and see if its valid - too many false dawns with eARC
Yeah, I know. But I also have talked to this guy quite a lot. And if he says he got the info from Samsung official product support specialists, I know he isn't lying. But you're right. It seems not even the seemingly most trustworthy Samsung personnel always gets it right. I'm "Peter Lindblad" in the conversation by the way. 😊
nuovagrafica
please, can someone enter in the develop mode and install nextplayer and juvoplayer for watch 8K videos ? I'm not able to enter
today the call center told me you have to press info menù mute and power button on an infra red remote controller or maybe info mute menù and power I don't remember exactly but I don't have another remote controller samsunng, can someonte to try please for to see if it works?
Stafford
I only have the silver remote as well.
nuovagrafica
hey guys help me to install nexplayer and juvo player for watch 8K movies from youtube
finally I entered in developer mode... with the silver remote controller click on APP and with the arrows press fast 1ok 2ok 3ok 4ok 5ok
  • Switch "Developer mode" to "On".
  • Enter the IP address of the computer that you want to connect to the TV, and click "OK".
  • Reboot the TV.
and follow this link Smart TV - Build | Samsung Developers
download Tizen Studio: Download | Tizen Developers
download NexPlayer Smart TV - Build | Samsung Developers
download JuvoPlayer SamsungDForum/JuvoPlayer
whitehart
  • Reboot the TV.
why you need this?
nuovagrafica
why you need this?
because on Q950R there is no app for play correctly video from usb like mkv, wmv, avi, dvix, xvid, vob and 8K video from youtube (the max resolution on youtube is 4K)
search 8K qbec city on youtube... the max resolution from PC is 8K, the max resolution on TV is 4K
you bought an 8K TV but you can't play 8K videos from usb or youtube, is it normal for you?
Stafford
I play 8k with Q950R just fine from USB with external USB hard drive. But if you find a way to play them from YouTube, sure, that's fine.
whitehart
I use my PC for this - i wouldnt touch those Smart apps - they never good
Abra20
I've been having really bad display flickers over the last few weeks. Is anyone else experiencing this, where the screen flickers on certain scenes, in particular scenes containing suits/material with very small lines on people. Or whilst gaming and moving around the edges of the screen blur up and flicker badly. I've also noticed the screen has become darker on some shows that never used to be dark.
whitehart
no nothing like that - just big buyers regret that i bought this model without eARC !
Abra20
Repair company said it looks like a faulty display. They've ordered the part to replace the whole TV screen. Has anyone else received another display panel?
Paul 8k
Hi ,
My 6 month old 82 950r has just gone wrong ,just turned off with led light flashing Samsung approved repairman came and took a look and has order a new panel anyone else had the same problem and was it resolved ?
as obviously I’m not very happy that the best 2019 tv Samsung make has developed such a huge fault.
Abra20
Hi ,
It's crazy how these TVs are failing so early on. The replacement panel as well looks refurbished so not new and was made in Vietnam, whereas the (inside sticker been ripped off and lots of scribbles in the panel inside) other panel was made in Slovakia.
The issue I had still hasn't resolved and the replacement panel has actually made it worse. They are going to change the main system board on the panel and one connect cable next time, but I got a feeling it's a faulty one connect box.
Feel so gutted after spending such a large amount of money and receiving such bad quality. Anyone got any tips on what to do next if the issue isn't resolved?
Paul 8k
That’s mad ,Have you asked for a replacement I take it’s still in warranty,who did you buy from,the repair man I spoke to says it’s very unlikely to ever be a one connect box as they don’t go wrong!!
I will see what happens with my panel if it’s not brand new I will be complaining as you say we’ve spent so much money on this flagship model
rozel
@whitehart My HDfury AVR Key is working perfectly :)
rozel
And that means you want 48gbps bandwidth as opposed to 18gbps, to do what exactly? To do better than to achieve a 4K picture at 60 FPS or an 8K picture at 30 FPS? I know that HDMI 2.1, on the other hand, promises 4K resolution at 120 FPS, 8K resolution at 60 FPS, and a ceiling that will ultimately support 10k - whoopee! And precisely where do we see that content? Don'tget me wrong but HDMI 2.0b does what I need - to split the video and sound and all HD sound. Unfortunately eARC will not pass the DTS HD formats due to licencing, which convinced me not to wait for this inferior option to get off my new media player, HDR10+ video and all HD sound.
Stafford
Of course, for audio purposes 2.1 and eARC is not really a must. For audio you can get around the problem with a good new avr.
For video however, and mostly gaming,[email protected] and [email protected] Hz will actually make a matter in games, at least when they eventually support it more frequently in the future. Fortunately, this TV has one 2.1-port already.
rozel
It's been a massive learning curve since buying this TV. I don't do gaming but if I did, I'd be doing it on a dedicated monitor. This TV is excellent but as and when Amazon and Netflix start streaming HD sound (probably not for years) I'll rue not having eARC. September is over in just over 24 hours and still no eARC - bet my Hdfury AVR Key, gets a firmware upgrade to HDMI 2.1 first haha!
Stafford
Well, glad that you seem happy. I'm quite comfortable with my Yamaha RX-V6A, 3 HDMI 2.1 ports and so many ins and outs, features and future proof support of everything one can need, so I will pass on the Hdfury. 😁😉
whitehart
if anyone wants to buy one of these superb TV's i found them at super low price on amazon - even lower than what i paid
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
Latest News
Tom's Thumbs: What is coming to Netflix in November 2020
  • By AVForums
  • Published
Melco anniversary edition N10 library announced
  • By Andy Bassett
  • Published
What's new on Disney+ UK for November 2020
  • By Andy Bassett
  • Published
Denon, Marantz and Yamaha AV receivers hit by HDMI 2.1 bug
  • By Andy Bassett
  • Published
McIntosh launches MX100 AV processor and MI347 power amp
  • By Andy Bassett
  • Published
