Samsung 850 with Sharp GA3E LCD - settings advice!?
Discussion in 'Blu-ray & DVD Players & Recorders' started by matt_s, Jun 2, 2005.
  1. matt_s
    matt_s
    Nov 29, 2004
    34
    Got my Samsung 850 yesterday. Connected it up to my Sharp LC26GA3E via a 5m HDMI-DVI cable from Maplin (quality looks a little dubious but I was in a rush to try it out! - still £29 though).
    Using the setting AV digital on the TV gave reasonable results but nothing ground breaking. My old player was a very old toshiba sd-2109 connected via scart so I expected to be blown away!? The picture quality is good just not great.
    I also tried PC digital on the TV and this displayed the image pixel for pixel which looked clearer but the image wasn't centred, was trimmed and looked pretty rubbish!?
    Is there any reason why the DVD player cannot output a signal that is closer to what my screen requires?
    Anyone else got the same set up care to comment, share their experience?
    Could the cable be duff?
    :smashin:
  2. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Have you got your hdmi settings on hdmi rbg or hdmi yb yr yc, you should use the latter, it comes out of the box hdmi rgb. If your lead is a bit dubious then try exchanging it but check the settings as i think that may help. :hiya:
  3. zoro
    zoro
    Jan 23, 2003
    326
    +7
    US version has HDMI, normal, expanded YRB 4:2:2 and 4:4:4 options only!
  4. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Matt S
    I have a 850 attached via hdmi to hitachi 42pd7200 and not as good as tosh 330 component but less noise
    Rgb -n expand , 444 422 not much diff
    I hope this helps i thinks its what youe use to
    Azz
  5. daveyjay
    daveyjay
    Nov 18, 2004
    59
    +10
    Look on thread GA3-GA4 settings on LCD forum.
  6. matt_s
    matt_s
    Nov 29, 2004
    34
    I was in quite a rush to get the thing set up so I imagine I am using RGB, will check tonight. Cheers for the feedback
