Samsung 850 or 745? Which one is better?
Discussion in 'Blu-ray & DVD Players & Recorders' started by indyjones, Sep 9, 2005.
  1. indyjones
    indyjones
    Mar 4, 2005
    47
    I was just wondering why the 745 costs more than the 850 (don't higher numbers usually mean better performance?)? Is the Samung 850 a decent Player? I'm going to buy myself a Pana 700 Projector, and I want a HDMI/DVI DVD player that can upscale to 720p. I was going to go with the Denon 1910, but the Samsung is almost half the price. So which one should I buy (if I should buy a Samsung at all)? Thanks a lot!!!
    Indy :)
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    I found the Samsung 745 output via DVI far too soft for my liking. I suspect it's a Samsung trait and the 850 may be similar.
    I recently bought the Oppo from ITSupplies.net. Far clearer pic on a projector, and the panning shots are a lot smoother. You can select a DVI to HDMI lead for free.
    Slightly more expensive at just over £170 but very much worth it...PJ :)
  3. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    If your after an 850 i have one in the classifieds.
  4. indyjones
    indyjones
    Mar 4, 2005
    47
    Thanks, but I'm on the mainland right now.
    What do you mean when you say "soft"? I can get the 850 for 135 Euros here, which is pretty damn cheap. I'm going to buy a HD player anyways in a couple of years, so I don't want to make a big investment now.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    It simply lacked detail. I'm sure it would look fine on a 42" plasma but when you are looking at pics 7ft diagonal you need a player that can pass through the signal with pin sharp clarity.
    My Pioneer 575 via component was a much better pic than the Samsung 745 via DVI. The Oppo is ever clearer than the 575, albeit you see more noise on poor DVD transfers. Must stress I haven't seen the 850 in action so I'm not certain it will be the same as the 745.
    Like you I'll be investing in HD in a couple of years but the Oppo will more than prove its worth in that timeframe I'm sure.
    ...PJ :)
