Samsung 730MW-Some questions before buying
Discussion in 'Samsung TVs Forum' started by iknownothing, Aug 10, 2005.
Tags:
  1. iknownothing
    iknownothing
    Ive been looking for a cheapish TV and this is the one I keep comng back to. I have a few questions about it
    Whats the display quality like?(especially for gaming on xbox and gamecube)
    Will it be any good for Sky HD broadcasts and other high definition things (xbox360, HD-DVD players)
    what resolution of HDTV does it support(720p etc.) as I have read that it is HDTV ready yet nowhere says what it supports
    Thanks for helping
  2. flying rooster
    flying rooster
    Can't really help you with the TV, but if it has "HDTV ready" asigned, it has to support 720p and 1080i and it must have a DVI or HDMI and a YUV connection, so HD broadcasts, XBOX360 and HD-DVD players shouldn't be a problem. In fact the "HDTV ready" seal was created just to garantee this.
  3. iknownothing
    iknownothing
    Here's an answer to my own question from Samsung! I sent them an e-mail asking them what it supports and got this answer:
    The unit is hd ready through component and DVI(HDCP) terminal
    1080i is supported at 1280x768.
    So.... looks like Ill be buying it!
