samsung 709 help
Discussion in 'Blu-ray & DVD Players & Recorders' started by jmack, Aug 20, 2002.
  1. jmack
    jmack
    i have 3 year old samsung 709 dvd it was multiregion chipped at techtronics 3 years ago,
    so i try it plug it in and now it says this (disk is the wrong region)
    it does this for both regions 1 and 2
    any ideas ?
    can i reset it ?
    is there a hand set lock or some thing?
    cheers
    ps. it has not been used for 2 years if that helps
  2. paiger
    paiger
  3. dejongj
    dejongj
    I still have a Samsung 709, it is actually in our guest bedroom. I also bought it from Techtronics about three years ago.
    The region hack is as follows:
    1. Ensure the player is on standby (powered off, but not really)
    2. Press and hold the number of the required region for about 20 seconds.
    3. Turn on the player
    4. Voila it is done....
    Have fun...
