JamieBee
Hi. Im just about to order one of these but have a small doubt as I’ve read a couple of mentions online about a local dimming problem with tv. Not sure if this was caused by or can be fixed by a software update.
I had a low end Samsung LED a few years back and I found the local dimming so annoying, I ended up going into the service menu (using a guide on YouTube) to disable it in the end. I currently have a Samsung Crystal LED tv and it’s not a problem (not sure if it even has it ?).
Is this a problem on the tv for any that own it ? This tv had got the nod over the LG C1 so if anyone can clear this up, I’d be most grateful.
Thanks.
Thanks.
