Samsung 50 "
Discussion in 'General TV Discussions Forum' started by jibber, Sep 19, 2005.
  1. jibber
    jibber
    I've been looking into the dlp rear projection and this one springs to mind simply because of the cost and features..
    has anyone bought one of these and can give any review on it ?..
    Samsung SP50L7HX (50" dlp rear projection tv)
    look forward to hearing about it, price wise range from £2,500 down to cheapest so far £1,725
    Jibber.
  2. Ruby
    Ruby
    Jul 27, 2001
    998
    28
    Coventry
    +82
    Where is it on sale for £1725?
  3. skip
    skip
    Jan 17, 2005
    108
    had this set for about 3 months now after taking back the tosh 46 dlp. top set you wont regret buying one . look around there are plenty of threads on this set, as ive said before just remember this set was nearly 4 grand when it first came out and boy does it live up to its price tag.hope this helps any best of look :smashin:
  4. jibber
    jibber
    hi, urm i think the place i saw it for that price was avwow.com..
    onyl just started looking online yesterday for it and still need some more searching..
    is it true that once the brightness gets poor that you can simply change the bulb and all things become good again, if so how much is a replacement bulb ??..
    looks like i'm swayed to buy one of these now just a case of a little bit more research and popping into a few more shops that stock it and looking and asking some questions about it..
    Jibber.
  5. lesliedocherty
    lesliedocherty
    Had this for 3 months aswell, amazing tv, got it from pixmania with the hdmi dvd player for £1,800, good buy.
    Although i never received the matching component stand.
    leslie
  6. Fraudster
    Fraudster
    Sep 11, 2005
    61
    Coxhoe, County Durham
    whats the differance between the 7hx and the 6hx model?
    as there seems to be a good few hundred quid differance? :confused:
  7. jibber
    jibber
  8. Fraudster
    Fraudster
    Sep 11, 2005
    61
    aii im looking for somewhere that will let nme have this tv on either 12 or 24 months interest free
    not having much luck
    ill keep y'all posted
  9. slackbladder
    slackbladder
    Oct 7, 2003
    1,252
    4
    67
    "London, a small village on Mars..."
    +110
    At my Brittain and Hobbs they do 12 months interest free and they have Samsung and Toshiba. However, high street only so the price is not as good as online stores. I think they're something to do with Euronics or something?....
  10. jibber
    jibber
    just to add to the comment, i too would like to know what the difference is between the two models... :D
    jibber.
  11. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    One has the fixed centre pedestal which doubles as a stand as well as containing the electronics and optics, and the other is more like a conventional TV set with a normal stand that you can choose to use or not.
    Look at a pic of the Samsung SP46 - this is just a slightly smaller version of the SP50L6HX.
  12. slackbladder
    slackbladder
    Oct 7, 2003
    1,252
    4
    67
    +110
    On this thread is noted that the 7HX has a HD2+ chip and the 6HX has the HD4
    link
    It suggests the 7HX has a slightly higher contrast ratio as well as the rather striking pedestal stand.
    The SP50L6HX would be quite a buy (seen it for £1440-ish at Robertsons) but not seen it anywhere else and no idea when it will be available. I've recently purchased the Sp46L6HX...though it's taking 2 weeks to get here..ho hum.
  13. oreoshake
    oreoshake
    Sep 21, 2005
    4
    The SP-50L6HR uses the HD3 chip. This is available in the Philippines. I think this is the same model, named SP-50L6HX found in other asian countries such as Singapore and Malaysia.
  14. kurt_ego
    kurt_ego
    Mar 25, 2005
    70
    the 7x is far better pq!! i have one and its amazing as long as you spend the doe on gud quality wires!!! One minor prob is that any defects in the picure. eg copied dvds (of course i dont have any) any imperfections are amplified.
    Kurt :smashin:
  15. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Given that the 6x has yet to make an appearance in the shops, let alone undergone comparison testing, what are you basing this conclusion on Kurt?
  16. jibber
    jibber
    ok i've definitly made me decision to buy one now
    my only problem is where to buy and looking for a best price... but weighing up the cost, John Lewis allways offer a 5 year warrenty so it may be worht paying the little extra for the warrently (john lewis price is £2,399, maybe with a price match which costco selling it at around £1,999 might be worth it with the 5 year warrenty)
    i know that the price matching has to be from a shop rather than any online place which they won't price match on..
    anyone else got any better ideas ??..
    Jibber.
  17. dUnKle
    dUnKle
    Jan 1, 2001
    15,268
    +2,274
    couple questions on this
    anyone do them on 12 months interest free
    and where does centre speaker go
  18. FGEvans
    FGEvans
    I got mine on 12 months interest free from Pixmania for just under£1700.
    No complaints about the price or service
  19. dUnKle
    dUnKle
    Jan 1, 2001
    15,268
    +2,274
  20. jibber
    jibber
    what warrenty does pixmania give ? standard manufatures of 12mths ??..
    so would it be worth payin an extra £200 for four more years cover ??..
    Jibber
  21. jibber
    jibber
    did you get the extra floor stand for the video and dvd to sit on from pixmania, i ask this as it dow not state anywhere that it comes with the stand, with the ammount of unit's i have the stand would be essential..
    Jibber.
  22. dUnKle
    dUnKle
    Jan 1, 2001
    15,268
    +2,274
    Interested in that too
    Can not see stand listed :(
    So any other 0% deals on it - preferably from somoen who can get it with me next week too :)
  23. jibber
    jibber
    i've ordered mine yesterday, should be delivered on monday so will be looking forward to that.., got itfrom john lewis in the end for a price match against costco, also i get five years cover instead of three :), looked into the cover to buy alnoe which would cost £299 for four years (plus one year extra manufactures) so even if i bought at pixmania for £1,728 i'd still be paying more with the cover to pay on top..
    getting excited now and can't wait !..
  24. Jamesy_UK
    Jamesy_UK
    Sep 27, 2005
    430
    +11
    Lucky boy Jibber ;), was already to place my order until I got my credit card bills rofl, just got back from my Honeymoon. My wife's father who agreed to pay half for the wedding has now changed his mind and wont stump up so we are up to our eyeballs for the next 6months, slimy bast I could kill him.
    anyone know someone who likes hanging people from their ankles and shaking them?
  25. Scoob
    Scoob
    Apr 26, 2005
    119
    Yes, but she charges £150 an hour :D
  26. dUnKle
    dUnKle
    Jan 1, 2001
    15,268
    +2,274
    well mine has just arrived and when will I learn
    The box only just fits in the house
    Now need to get it upstairs
    Is it ok to lift it by the screen
  27. Jamesy_UK
    Jamesy_UK
    Sep 27, 2005
    430
    +11
    Sick puppy
    and keep the tv upright where possible and dont touch the screen duncan ;)
  28. dUnKle
    dUnKle
    Jan 1, 2001
    15,268
    +2,274
    Well its there and running and now have one hell of a mess to sort out
    I pvt messaged one of you guys regards what settings I should be using but the message has gone - so if anyone can post optimum settings would be grateful
  29. tony6403
    tony6403
    I have now finally decided to get an SP50. Went to Comet . £2,499 in store. On line it drops to £2,199 . Saw it on line at Currys for £1,824. Rang Comet who , under their price watch arrangement have agreed to supply for £1,786 this price being 10% less than the difference.
    I asked about the shelves ( for the pedestal model ) which Comet claimed never to have heard of . I rang Samsung who said that the shelves came as standard with the telly. Rang Comet and told them and they then rang me back to say that this was in fact correct . So I will tomorrow order the SP50 , on line from Comet at £1,786 complete with the shelf unit . What a bloody performance !
  30. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Great price for that set mate!
    Comet are much more reliable than Currys too, especially when it comes to after sales service.
