Samsung 50" Plasma - wall mounting to stand HELP PLEASE!
Discussion in 'Home Cinema Buying & Building' started by MrKennedy, Feb 12, 2009.
  1. MrKennedy
    MrKennedy
    Sep 14, 2008
    2,254
    +107
    Hi guys,
    I'm really needing some help :confused:
    I currently own an 'Ikea Tobo TV Unit' it has the option of buying a seperate back 'TV panel' which will hold 50kg (TV) and attatches to my current 'Tobo' unit.
    The problem i have is that, the holes on the tv panel are actually centrally placed for the wires to feed through!
    yet...on many of the wall mount bracket i am looking at for my particular TV the holes for the cable feeds are spaced out quite abit to the sides!
    How i get around this? would i just have to drill new holes in the tv panel itself?
    Please help, thanks!
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    We have this bracket which should solve your problem;
    M-Form - 32" to 52" Universal LCD/Plasma Bracket
    There is a large space in the middle for getting cables through which should give you quite a bit of flexibility for mounting position.
    Price includes free delivery and our FIT-RITE Guarantee.
    Regards
    Graham
  3. MrKennedy
    MrKennedy
    Sep 14, 2008
    2,254
    +107
    Thanks, this is what i'm after :thumbsup:
