Hi there
My first posting! I was searching the forum history but coudn't find anything regarding problems with a Samsung 46D8000 that won't connect or see any wireless routers.
Whatever configuration I try and set on the TV the setup for wireless routers doesn't seem to connect to my DLINK router. I've made sure MAC filtering is off and made the SSID visible. The strange thing is that the TV doesnt find any other wireless lan (except once briefly) although there are several in the area. Also the TV only spends about 5 seconds searching before coming back and saying none are available.
Has anyone else seen this problem - any help would be much appreciated.
Kind regards
Kind regards
