samsung 46" 786
peshi
Buying this tv and want to connect my macbook pro via its dvi output.
Will the picture be as good as the macbook pro 15" screen?
Maniac618
Can the macbook output at 1920x1080? If so the answer is yes, if no then the answer is no. It'll look ok, but won't be the TV's native resolution so won't look as good as the macbook screen. You might not be able to find out if it can output at the above res until you actually connect it anyway.
