Samsung 43 inch plasma question
Discussion in 'Samsung TVs Forum' started by gonzo123, Aug 21, 2013.
  1. gonzo123
    gonzo123
    Jul 4, 2010
    11
    Hi, i have saw people on here saying to disable digital clean view and mpeg noise filter, my question is why have these off if the purpose to have them on is to make the picture better, i currently have them set to auto, just looking a reason to why they should be turned off as suggested here. Cheers
  2. gonzo123
    gonzo123
    Jul 4, 2010
    11
    Anyone? I thought this forum was full of tv experts
  3. martinthorn1
    martinthorn1
    Mar 6, 2011
    218
    Hampshire, Uk
    +46
    Those features are only needed if you have a noisy or poor picture to begin with. Otherwise they will actually make the picture quality worse and therefore should be kept off/disabled.
  4. gonzo123
    gonzo123
    Jul 4, 2010
    11
    Thanks for your reply, just one more question black tone off or on? I have 3 options dark darker darkest?
  5. JayCee
    JayCee
    Jan 20, 2004
    23,501
    Lanarkshire
    +2,532
    Why not just look at the picture and toggle between all 3 settings and leave it at the setting that looks right to you?... Not what others suggest.
  6. gonzo123
    gonzo123
    Jul 4, 2010
    11
    well you are the experts so looking the most preferred option
  7. martinthorn1
    martinthorn1
    Mar 6, 2011
    218
    Hampshire, Uk
    +46
    I have Black Tone to 'off' as this is supposed to give a more accurate reproduction of whatever is displayed by the tv. However if your eyes prefer a different setting then go with that!
  8. Matt_C
    Matt_C
    Aug 14, 2005
    9,794
    Essex
    +1,786
  9. gonzo123
    gonzo123
    Jul 4, 2010
    11
    I know but i just bought this plasma yesterday and was just looking some basic picture setup advise, also my plasma is 720p does it matter if my xbox and virgin media output is 1080i? Should i change this setting?
  10. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    asking a question in the middle of the working day is not the best time for a quick reply, please bear this in mind.
    Curly
  11. Matt_C
    Matt_C
    Aug 14, 2005
    9,794
    Essex
    +1,786
    I get that - if I had the same TV and had changed the settings to my preferences, I'd gladly list those settings for you to try, and you might find they are good for you too, or find they aren't so good.
    But at the end of the day, it boils down to what you like to see after playing with the settings. But I understand, it's nice to get a set of basics to start from, and build from there
