SAMSUNG 40JU6400, 40JU6410 or LG 43UF770V
Discussion in 'What Is The Best TV For You?' started by PAULRYAN52, Jul 5, 2015.
  1. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    hi, I'm buying a 4k tv within the next two weeks, I'm stuck between these three, I watch a lot of sport and action films, I will be subscribing to netflix or amazon soon so it needs to be able to support them in 4k, budget is £750 and I will be buying it from Richer Sounds
    The tvs
    1. SAMSUNG UE40JU6400
    2. LG 43UF770V
    3. SAMSUNG UE40JU6410
  2. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    anyone help
  3. martinch
    martinch
    Jun 10, 2015
    33
    Hampshire
    Can't really comment much, but just FYI, the Samsung JU6400 has quite narrow viewing angles - this may or may not be an issue for you.
  4. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    i just got the lg
  5. cfc482
    cfc482
    May 11, 2015
    32
    Scotland
    Let us know how the LG is. Thats one of the options for me as well.
  6. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    it seems good so far, just trying to find some recommended picture settings
  7. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    Hi, how has the LG worked out for you, one of the sets im interested in as well, thanks in advance.
  8. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    So far so good pq is great
  9. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    Cheers for that mate, may order today as found it at £589, looks to be a good all rounder. Replacing a 4 year old Sammy 40" but just wondering if worth the change.
  10. SimonP93
    SimonP93
    Aug 14, 2015
    10
    Nottinghamshire
    +5
    where did you find it for £589?
  11. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    Hi. Appliances online using a quidco code of £30 off, but typically, I've just bought the Sony 43" and I just get emailed a code from that site for £50 off TVs so try
    Use code: SMARTTV50
  12. SimonP93
    SimonP93
    Aug 14, 2015
    10
    Nottinghamshire
    +5
    Thanks for the discount code, I've just bought the LG 43UF770V from ao.com for £569 + £15 for sunday delivery so can't moan at that at all!!
  13. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    No worries bud!! Awesome stuff, be interested in your views, some time fitting the Sony today, so far so good.
  14. SimonP93
    SimonP93
    Aug 14, 2015
    10
    Nottinghamshire
    +5
    I'll let you know tomorrow mate, this will be my very first smart/4k tv so i'm excited to see how it will perform compared to my hd ready tv which i'm using now lol
  15. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    Great stuff. Yep same as me, had 1080p Samsung for 4 years but fancied a more up to date screen.
  16. SimonP93
    SimonP93
    Aug 14, 2015
    10
    Nottinghamshire
    +5
    Hello 'stretchy' thought i would give you an update, tv arrived at 7:45am this morning and was working perfectly by 8am :D, can't believe the difference! i've also received a 6 months subscription to netflix ultra HD for free as well!
  17. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    Hi, awsome stuff!! Nice way to start a Sunday! Playtime then.
  18. Mojoman0427
    Mojoman0427
    Jul 13, 2015
    29
    3
    Bedford
    Simon did you go for the 40 or 43 in the end?
    I think the LG is quality.
  19. Stretchy
    Stretchy
    Mar 9, 2010
    551
    46
    Ipswich
    +146
    I got the 43" Sony in the end mate but was so close to getting the LG so glad your happy with it.
  20. SimonP93
    SimonP93
    Aug 14, 2015
    10
    Nottinghamshire
    +5
    i went for the 43" as it was cheaper than the 40" for some reason and i absolutely love it! and 'strechy' gave me a discount code so i got £50 of as well! do you have any perfect picture settings for my LG?
  21. aditheman
    aditheman
    Aug 17, 2015
    7
    a
    for those who own the lg.. do you also use it for PS4 gaming?
    I am interested in LG 42LB670V, and would like to know how is the performance. may be similar..
  22. Mojoman0427
    Mojoman0427
    Jul 13, 2015
    29
    3
    Bedford
    I use my PS4 on the UF770v and it's spot on. Minimal lag if at all noticeable, and even if you do they have a "game" picture mode which turns off the processing and eliminates all noticeable lag.
