Samsung 32" LE32A457 auto source help?
Discussion in 'Samsung TVs Forum' started by Coppers15, Feb 13, 2009.
Tags:
  1. Coppers15
    Coppers15
    Jan 27, 2007
    4
    I've got a Samsung 32" LE32A457 and have it hooked up to my laptop as a second screen sometimes with sound aswell (AVG and 3.5mm Jack for pic and sound). I would like to have it hooked up all the time but i can't, as i use my laptop as my alarm in the morrnings.
    I know how to set the timer on the samsung to wake up the tv (normally about 2 mins after my laptop wakes up), but it always wakes up on the TV source and i don't know if i can get it to wake into PC source, so that i have the picture and sound from my laptop on my tv.
    I hope im being clear in asking is there a way i can do this, so i dont have to unplug the 3.5mm cable every night.
    Many thanks
    Coppers15
  2. Dude a llama
    Dude a llama
    Oct 8, 2006
    427
    28
    +61
    Buy an alarm clock for £2.99,problem solved.:thumbsup:
  3. Coppers15
    Coppers15
    Jan 27, 2007
    4
    mmmm never thought of that :mad: lol any other ideas
  4. ziffius
    ziffius
    Feb 5, 2008
    1,884
    83
    +292
    Try leaving TV on when connected to the PC so it enters power saving mode and resumes when it gets a signal from the laptop.
  5. Coppers15
    Coppers15
    Jan 27, 2007
    4
    thanks i'll try that
  6. Coppers15
    Coppers15
    Jan 27, 2007
    4
    nope still no luck, any more ideas?
  7. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    if you select the "pc" channel on the tv, and switch off the tv manually,does the laptop wake up the tv, on the pc channel then?
    mine does,on my 26", well my pc can, and it will wake on whatever channel was on before i switched it off.
    failing that, buy an alarm clock..
