Hi guy's,
After some advice if possible.
I recently purchased 32" Samsung D6100 for the 3D side of the TV. When I first started looking at the free 3D episodes that Virgin Media offer I was getting a sort of shadow to the right hand side of the objects in view on the TV. I was using HDMI 1.3 cables and read on here that 1.4 should be used which I bought and fitted BUT I am still getting this sort of shadow which, if you are anything like me, VERY annoying as its not perfect.
I have gone through the settings on the TV but have not sorted it. Do you think it maybe something to do with the Virgin box? I am going to buy a 3D movie to run through the PS3 to make sure thats ok.
I am also using SSG-3100GB active glasses.
Hope someone can help!
Thanks ahead
Thanks ahead
