Samsung 26r74 problem running HD via component
emporer
I have just bought one of these for the bedroom and have connected my Bufallo Link Theater upto it via a good quality set of component leads. TV itself is fine and sky via rgb scart is pukka, but on component it gives some 'lines', like power inteferance. Using the Link Theater on 1080i it gives diagonal lines about an inch thick that travel from corner to corner, and with 720p I get the same lines but they are much thinner, if I put the player to output 480p or lower its fine. Now I know the Link Theater is fine as ive just took it straight off my 42 panny plasma and that showed no problems at all. Its deffo not the cable as the lower resolutions are fine.
Anybody have any ideas? is it a faulty set?
emporer
My problem isn't the same as yours judging by your pix, mine is more like inteferance with lines travelling across the screen.
I phoned Currys today and they are delivering me a new one on Saturday, quite lucky its this side of Christmas.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
