Samsung 26" Problems. Please help.
L
liamraine1
Hi everyone, sorry if I've done something wrong in posting this.
But I have a question. I have the 26" samsung LE26R74. The TV has this really annoying function where the brightness constantly goes up and down depending, I noticed it whilst watching a movie. It's so annoying, anyway how I can stop this? I've looked through all the menu's..
Something I'm missing? Thanks.
Reckless187
My Samsung 40" also used to do this. Fix it by hitting the power button on your remote to put the TV into standby mode then press:
Info,
Menu,
Mute,
Then hit the poewr button again to turn the TV back on. It should now be in the service menu, if not, then repeat the process til it works.
I think you have to go to the 2nd or 3rd option menu down & there should be something called "Dynamic Dimming". Set this option to off & it should do the trick! Don't mess with any other setting though like I did, now my energy save feature doesn't work. Could be a coincidence or ralated to my fiddling with the settings, most probably coincidence.
