samsung 26" LE26R41BDX problems??
C
chippee
hi i know theres alot of threads about samsung LE##R41BDX tvs but ive search for info in what i would like to know but no luck.
right i ordered my LE26R41BDX Greenwich II LCD TV from play.com and i must say i the price grabbed me. anyway when i first set the tv up i thought wtf the quality of the screen was less quality than my old matsu asda tv 26"
iwas gutted then i tried a dvd, again compairing the 2 tvs and again my old tv was better, more detail was being seen and on the lcd smearing and less quality in the screen.
i thought this was a HD ready TV my god ps2 games look awful on it "gta sa in perticler" but anyway i was then told its down to the scart, rgb connection etc all i use is the 2 scart sockets 1 for ps2 1 for xbox so my my question is ,how do i push my tv to its limits you know when playing my consoles and watching dvds?do i need certain leads like gold scarts etc ive already ordered a vga theater lead to link my pc to the set.
because ive been told this tv had smashing screen quailty and i just do see it!
rubberducker
Established Member
jesus man. these sets look ***** with anything other than a stella signal pumped into them.
you tv is just showing the bad sources that your old crt hid.
you need to get componant or vga connections for all your games consoles and dvd.
forget rgb it will look ***** on this set compared to what can be achieved with VGA OR COMPONANT.
if it isn't already you will need your xbox soft modded (search the forums for help on that). and go and buy a new dvd player with a componant output that does progressive scan. only some games will be able to do it on a ps2.
only then will you see a difference. your new tv is designed with the future in mind - not ***** like scart.
C
chippee
hey thanks for that rubberducker ,i just didnt know what the hell all the other people were talking about with leads etc i might not bother with the xbox or ps2 leads though as im waiting for the xbox 360 to come out i understand that it comes with Hd Leads.
oh and another thing do this mean that when i get my vga leads for my pc connection does this mean i can run dvds through my pc and watch them on my tv with better quality?
spikecast
Hey mate. Thinking of order a TV from play.com myself..how long did it take? Because games take 3-5 days, also which courier delivered it? Cheers.
C
chippee
i had to wait 3 days for my tv to come the same as games i really like play.com in always order from there. :thumbsup:
spikecast
Thanks. One thing that concerns me is that I want one with HDMI but the same telly as you've ordered but without the freeview only says "HD Ready" I thought all of the 26" versions had the HDMI port? It's not the BX version just the normal one without the freeview..I can't see any way of contacting Play.com on their site either
UKBOY
Both have a DVI input so are "HD Ready".
I myself cant decide whether I should just order the non Freeview equipped version: I already have Sky so that would be duplication and I hear due to the proliferation of channels the picture quality is worsening ..........
Also, at least the "vanilla" version is in stock, the other one it seems is a bit too popular for its own good and is out of stock all over the place.
UKBoy.
Moogle
UKBoy.
Actually they have an HDMI connection and not DVI. Infact all the Samsung LE series 26", 32" and 40" have an HDMI connection, be it the Freeview version or non Freeview.
UKBOY
Oops, I stand corrected. :)
Cheers.
UKBoy.
spikecast
So will a standard VGA cable do? As I'm planning on using it as a monitor/TV you see.
Moogle
Yes it will. Infact from what some people have said the HDMI connection is not ideal as a PC input. VGA is supposedly better although even with that you msy need to download a utility called Powerstrip to adjust the resolutions on your PC to match that of the TV. At the end of the day VGA is probably better though.
spikecast
Thanks. I've got a spare one here luckily :)
C
chippee
yes i have pre-ordered a 360 with play.com and YES i am getting one from them lol i orderd mine in the middle of the year and they said as long as peopl ordered b4 22 aug your defo getting one.
ive orderd a gold theater vga cable so i hope it gives good results :D
anyway whats the best cable to get for my xbox for this tv and where from do they do vga cables for it , i cant find none.
Moogle
You do know that in order to connect the 360 using VGA you have to get the 360 specific VGA cable right ?
Waynej
You will need to import the xbox hi-def pack and soft mod your xbox, post in the xbox section, there should be plenty of people there to help you out
Moogle
chippee said:
yeah i know that but is there a vga cable for xbox 1??
if not what should i get?
There isn't one for the Xbox. I was referring to the 360 that you're planning to get as there will be one for that. For the Xbox the above option is what you need, a soft mod and an advance HD pack ( essentially an Xbox specific component cable ).
Woods C18
Ive had this TV for a couple of months now and it has improved with time. LCD's take time to 'bed in' so to speak. Also, you wont see what your tv is capable of untill the xbox 360 comes out. Here is what ive done for best picture quality: Xbox into scart RGB, DVD into component (mine is not upscaling so it will look much better if it was), PC into VGA and Pace Sky digital into scart 2 (non rgb). Ive found that this tv dosn't like sky's rgb signal and im prepared to put up with an average picture in the knowledge that sky hd isn't a million years away.
C
chippee
i now got a vga theater cable it works suppub just a bit of tinkering with the video card the screen found its own size for the desktop etc but when i open up media player of any typr of dvd player application i cant seem to get or even find and option to get my screen at full screen, its only showing 4:3 ratio and it aint showing 16:9 ive tried the tv remote for picture size etc. i just wonderd has anyone got rid of this my video card is a navida geforce 6800 GT
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
