Samsung 26" LCD HDTV
Discussion in 'LCD & LED LCD TVs' started by Waynej, Aug 4, 2005.
  1. Waynej
    Waynej
    Oct 4, 2004
    6,493
    Wales
    +861
    SAMSUNG LE26R41BDX/XEU
    I am seriously considering buying this for use for Xbox 360 and Playstation 3, is it suitable?, the one thing I couldn't find was the response rate, I believe someone said it needs to be 16ms or below to be any good, if anyone can find that out, that would be great. Also I read that the Xbox does not connect by HDMI but composite (not sure if thats true), thought i'd mention that as according to the website it has no composite inputs.
    *******LINK*******
    Also, leave your thoughts on the set and whether u know of any other LCD's upto a limit of 700 pounds.
    Thanks :smashin:
  2. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    There are extensive threads on this very set, and also in it's 32" guise.
    Yes, the 32" thread is massive, but I suggest you go take a look as the sets so far appear to be exactly the same, albeit the 26" doesn't seem to suffer from the tearing in 720p.
