SAMSUNG 20" LCD TV as a pc monitor? A good choice?
Discussion in 'Samsung TVs Forum' started by alextech, May 9, 2005.
Tags:
  1. alextech
    alextech
    I'm thinking of getting a Samsung 20"LCD TV (LW20M2CIX) to use primarily as a PC monitor. AT 399GBP this seems to be the most inexpensive way to get a decent sized flat monitor for my PC. The TV does have a PC input, so can be used with a PC.
    Is this a good choice or are there any reasons for not going down this route. Alternative suggestions welcome.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,391
    Somewhere in South Yorkshire
    +5,780
    Not good. Very low (VGA = 640x480) resolution if you are to believe retailers' sites/specs. Most (or all?) 20 inchers are, for some reason.
    If you want this size, there's a higher res Sony 21, but I don't know if it has a PC input. Otherwise, strangely smaller and larger sets both typically have higher res.
  3. mrm3
    mrm3
    Oct 29, 2004
    2,034
    48
    Cobham
    +94
    Better off getting the Dell 20" 2005FPW or Dell 24" 2405.
    Great widescreens for PCs with excellent specs for good prices.
    I recommend the 24".
