Samsung 1080p7 Firmware check
C
craigie
How do i check which firmware version i have for the Samsung HD1080P7?
I am going to attempt to upgrade to the latest firmware version though i don't want to do this if i am already up-to-date.
Samsung have emailed me stating that the firmware upgrade should remedy the problem of "set-up" changes being reset once the maching is switched off.
Does anyone know if the region hack will work with the new firmware.
It certainly works with my machine as it as and i only bought it from Richer Sounds last Friday.
C
Curly99
when you put in the disk with the firmware on it checks and tells you the firmware you have and the firmware on the disk. you will have 2 options cancel and total (whatever this is) click total if you want to update, I applied the hack afterwards but at the present time I don't have a disc to see if it fully worked.
Curly
