C
craigie
I am connecting the above player to a Sharp 42xD1E LCD. I read a review on the Samsung 1080p7 and people mentioned that when you change the Audio from PCM to Bitstream it makes a big difference. (The PCM Audio is fine at the moment)
If i change the DVD Audio setting to Bitstream and try and play a DVD disc it says "HDMI Audio not supported)
What does this mean? My TV should be able to take this signal
I have a cheap HDMI cable, could it be this?
Ta
Ta
