Samson amps, anyone used them?
Discussion in 'AV Receivers & Amplifiers' started by nathan_silly, May 15, 2003.
  1. nathan_silly
    nathan_silly
    As some of you know I'm looking at getting a SVS CS-Ultra soon.
    I've spotted the Crown K1 amps, seem good but they shut off several times in a minute for some reason.
    Anyway, I can get a Samson S1500 for £480 inc Vat & del.
    Commens regarding Samson, versus "Hi-Fi" brands and other PA amps appr. (and the S1500 specs)
    Nathan
    Here's the specs..
    Rated Output Power, per channel (1 kHz, THD 0.1%, Both Ch Drive):
    Stereo/Parallel modes
    per channel (into 4 ohms) 780 W
    per channel (into 8 ohms) 550 W
    Bridged mode
    per channel (into 8 ohms) 1550 W
    Frequency Response (0 dB, +0.5, -1 dB) 9 Hz - 42 kHz
    Total Harmonic Distortion
    (1/2 power @ 20 Hz - 20 kHz, Both Ch Drive into 4 ohms)
    0.021%
    Dynamic Range 101 dB
    Channel Separation (4 ohm, 250 W, 1 kHz) 82 dB
    Residual Noise (0 dB ref. = .775 VAC rms, 22 Hz - 22 kHz)
    (Att. Min.) -70 dBu
    (Att. Max.) -65 dBu
    Voltage Gain (4 ohm, 1 kHz) 37.3 dB
    DC Offset Voltage 0 ± 100 mV
    Damping Factor More than 100
    Indicators
    Clipping LED 1 kHz THD 0.1%
    Signal LED Right -20 dB ± 2 dB
    Signal LED Left -40 dB ± 2 dB
    Dimensions (W x D x H): 19 x 9.75 x 5.25 in. (482 x 247 x 133.35 mm)
    Weight: 48 lbs. (21.8 kg)
  2. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    nathan ...
    You'll probably want to make sure you see any PA amp before buying it as most have fans in.
    Crown / CA are reguarded as the best in the trade, followed by Crest. Then come a whole bunch like Carver. Trying to think of any others out there ... it's actually been a while since I was involved with any PA stuff.
    Vikki
  3. nathan_silly
    nathan_silly
    Thanls Vikki.
    The Samson does have two fans. I'm just wondering how hot the unit gets in normal use with the Ultra, or how hard you have to push it for the fans to kick-in.
    If they switch on after several hours for 10mins to cool down it'll be OK. But if they're on constantly after 20mins that'll be annoying.
    Crown K1 doesn't have fans.
    Here's the thread I posted on avsforums. I'm the original poster :)
    http://www.avsforum.com/avs-vb/showthread.php?threadid=257764&goto=newpost
    Info on the Samson S1500
    http://www.samedaymusic.com/product--SAMS1500
    Crown K1
    http://shop.store.yahoo.com/aicons/crowk1powam.html
  4. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    I think the fans will probably be on continuously ... certainly all the PA amps I've come across do.
    Vikki
  5. Spligsey
    Spligsey
    Jan 16, 2003
    2,358
    UK
    +217
    Nathan.
    Have a look here mate:
    http://www.matrixamp.com/4frame.html
    I used one with my HC.
    I disconnected the fans because after hours they were cold to the touch......i suspect it depends on how you use them & where they sit (ventilation).
    These things can blast!
    Adzman
    EDIT I was using the UKP series.
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,464
    United Kingdom
    +1,935
