Sammy SP50L7HX Lamp Life?
Discussion in 'General TV Discussions Forum' started by garyajohnson, Mar 9, 2006.
  1. garyajohnson
    garyajohnson
    My TV's is only new but I was wondering how long my lamp is expected to last and also where do I buy them?
  2. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    Easter Ross, Scotland
    +302
    If this helps, here's a statement from Samsung UK on a similar TV (SP46L6HX):
    The expected life span on a bulb for this unit is 45,000 hours and a replacement bulb can be purchased from a company called CPC and they can be contacted on 0870 120 2530.
  3. troylee
    troylee
  4. arfster
    arfster
    Jan 17, 2006
    1,459
    63
    +132
    There's no way a bulb will last for 45k hours, that's just the helpdesk being clueless. Expect 10k at most, and maybe 5k if you're unlucky.
  5. andywilliams007
    andywilliams007
    Troylee - which model did you select for the SP50 as it is not listed on samsungparts.com and have you tested your replacement bulb?
  6. tiburs
    tiburs
    Tv models are the US names HLR5087W or HLP5085W, so the bulb model is
    BP96-00677A.
    Check your set, You should find a small sticker somewhere with that exact bulb reference.
  7. sharonll
    sharonll
    Mar 17, 2007
    I bought my sammy november 05 bulb went last week checked out forum and bought from samsungparts.com cost $149.99 plus $39.95 shipping and $5.50 handling got to england quick stuck in customs for a few days then had to pay parcel force 29.96 for vat and clearance fee but still cheaper than prices in uk equalled to approx £135.00. cheapest price here was 189.99
  8. ioanab
    ioanab
    Feb 7, 2008
    2
    how is samsungparts? can you recommend them? is the lamp still working?
    Thanks,
    Ioana
  9. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,224
    oxfordshire
    +401
    I have 12000 hrs on my bulb, its probably at the end of its life now, but the picture is still good.
    Managed to get a new bulb from ebay for £96 delivered:thumbsup:
  10. Simba
    Simba
    Apr 11, 2006
    6,356
    Scotland
    +819
    anyone here need the corner stand for the sammy? i have one iv been trying to get rid of since i dont have the tv no more - stand is mint condition:)
  11. DLPhopefull
    DLPhopefull
    Jan 26, 2005
    87
    Barnes London
    Sorry off topic!
    Simba how do you compare your Panasonic to the SP50L7HX? Are they a lot better?
    I have had mine for a few years now and am not sure if its worth the change yet.
    Any comprison would be great.
  12. ioanab
    ioanab
    Feb 7, 2008
    2
    did you get only the bulb or the whole lamp?
    how do you change onlythe bulb?
  13. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,224
    oxfordshire
    +401
    I got the whole unit not just the bulb
  14. Simba
    Simba
    Apr 11, 2006
    6,356
    Scotland
    +819
    hi mate - tbh i never had the sammy dlp long enough for HD viewing. i had too many issues with it (ntsc jitter, hourglass convergence) - even though i had about 4 replacements. apart from that i found SD to be excellent on it. SD on the panasonic is also excellent (SD footy on good sources looks really good, and very little arterfacts i see on SD, i think much like the sammy) and HD is also brilliant. the plasma is also not exactly perfect, i have the faint lines issue on it that a few others have also reported but it is a rare issue and on mine its not that noticeable, plus image retention is also appararent but it does fade away after some time. in terms of PQ im very happy with it- especially blu ray.
    If you were to get the panasonic im sure you would be happy with it and consider it a step up in terms of HD. Just needs some tlc at the start for running in.
    :hiya:
    p.s corner stand anyone? :)
  15. dUnKle
    dUnKle
    Jan 1, 2001
    15,924
    +2,912
    What seller or item number ?
    Or can you point me to the same on ebay ?
    My bulb is coming to end of life and could do with replacement ?
    Is it easy to replace ? is there a guide anyplace ?
  16. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,224
    oxfordshire
    +401
    here is the link to the one I bought, very easy to replace and instructions are in your manual
  17. dUnKle
    dUnKle
    Jan 1, 2001
    15,924
    +2,912
    looks like all gone :(
  18. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,224
    oxfordshire
    +401
    have you tried sending him a message, he may be able to source one for you
  19. dUnKle
    dUnKle
    Jan 1, 2001
    15,924
    +2,912
    Done - just waiting on them being back in stock
  20. GAZZAWAT
    GAZZAWAT
    Sep 22, 2008
    Hi mate i have the sp50l7hx does the screen keep going off when the bulb is going but the sound is ok
    thanks
  21. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,224
    oxfordshire
    +401
    Welcome to the forum GAZZAWAT, so when the screen goes off, is the bulb still working, and does the tv switch on then off sometimes? Thats what mine did when the bulb was going, new bulb sorted it out.
  22. Jamesy_UK
    Jamesy_UK
    Sep 27, 2005
    430
    +11
    That SP range (46/50 etc) had a PSU issue that also caused the screen to shutoff and sound keep going, I had an engineer take a look and he replaced a few suspect looking caps and it was good as new (6months ago it was done) cost me 30quid.
