Sammy SP50
Discussion in 'TVs' started by FGEvans, Apr 6, 2005.
  1. FGEvans
    FGEvans
    Can anyone provide me with the actual dimensions of the sammy TV.
    I have a Tosh 42inch RPTV at present and want to find out whether the sammy will fit in the space that the tosh now occupies.
    I need an idea of the width of the TV and height from the bottom of the TV to the top. Also how deep is the back of the TV from the front screen.
  2. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    Dimension ( W*D*H ): 1361*520*1389
    taken from samsung uk website
  3. FGEvans
    FGEvans
    thanks.
  4. FGEvans
    FGEvans
    can anyone provide the dimensions of the footprint of the stand itself. Ie how long is the longest side, how long is the opposte side and how wide is it.
    I would also be grateful for details as to how thick the actual tv is at the top. I note from the pictures that the TV seems quite thin at the top and i assume therefore that it tapers downwards and gets bigger.
    The reason i ask is that i have a shelf which is set at about 136 cm off the floor. The tv itself i understand is 138 cm. However the shelf itself is only about 40 cm wide.
    Therefore is was hoping that the tv would still fit in with the top of the screen simply overlapping the edge of the shelf above.
    Any pictures taken side on would also help me.
    Is this tv better than the sagem axium , picture wise
  5. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    i will post some pictures for u today of tv back etc
  6. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    this is the side view of the samsung
    the stand is nearly as wide as the tv i would say around 6 inches shorter on each side
