Hi all. New the the site and was just wondering about if anyone has or has had the following Plasma TV listed above.
I found some handy specs on the TV which are followed below; but at a quick glance on google a few people claim this TV also displays in 1080p which would be great as i often play the PS3 and those extra frames would be benificial for movies aswell.
Also a quick question about Anynet+, I never had the chance to try it out with my LE32B450, probley because my PS3 is the Phatty.. So am awaiting the Slim to arrive. But can SKY HD be sync'd with Anynet+?
So in a nut shell do you think its a good buy to replace my Sammy LE32B450?
Thanks,
::SPECS::
Series: 4
FilterBright: FilterBright
Video
Screen Size (cm): 50"
Resolution: 1365x768
Picture Engine: DNIe+
Dynamic Contrast Ratio: 2,000,000:1
Contrast Ratio: 40,000:1
600Hz Subfield Motion: Yes
100Hz: 100Hz
Wide Colour Enhancer: WCE 2
Number of Colours (Expressed): Natural True Color (18bit)
Grey Level(Gradation): 262,144
Film Mode (Cinema Progressive): Yes
Digital Comb Filter: 3D
Digital Noise Reduction: Yes
Audio
Sound Effect System: SRS TruSurround HD
Dolby: Dolby Digital Plus
Speaker Type: Down Firing
Sound Output(RMS): 20W (10Wx2)
Features
Anti Burn-in Technology: Yes (APS, Signal pattern, Side gray)
Teletext(TTXT): 1000P
Anynet+ (HDMI-CEC): Yes
User Interface: Intelligent
OSD Language: 25 Language
Sleep Timer: Yes
Clock & On/Off Timer: Yes
Auto Channel Search: Yes
Auto Power Off: Yes
Power Saving: Yes
EPG: Yes (8 Days)
Auto Volume Leveller: Yes
Detail Settings: Yes
LNA Plus: Yes
System
DTV Type: DVB-T/C
MPEG4: Yes
DTV Tuner Built-in: Yes
Input / Output (Side)
HDMI: 1
Cl slot: 1
Composite(AV): 1
Input / Output (Back)
HDMI: 2
USB (Service Only) 1(service only)
PC input (D-sub): 1
PC Audio Input (Mini Jack): 1
DVI Audio Input (Mini Jack): 1
Component(Y/Pb/Pr): 1
Digital Audio (Optical): 1
RF Input : 1
Audio Out (L/R): 1
RS232C (Service Only): 1 (service only)
Scart: 1
Design
Type: High Glossy
Colour: Black
Stand Neck Type High Glossy
Swivel (Left/Right): Yes
Dimensions
Set Size(WXHXD) with Stand: 1220.8x810x316
Set Size(WXHXD) without Stand: 1220.8x748.8x74
Set Weight with Stand: 35
Set weight without stand: 31.3
Thanks,
::SPECS::
Series: 4
Video
100Hz: 100Hz
Audio
Features
Sleep Timer: Yes
Auto Power Off: Yes
Power Saving: Yes
EPG: Yes (8 Days)
LNA Plus: Yes
System
DTV Type: DVB-T/C
MPEG4: Yes
HDMI: 1
Cl slot: 1
Composite(AV): 1
HDMI: 2
PC input (D-sub): 1
RF Input : 1
Audio Out (L/R): 1
Scart: 1
Design
Type: High Glossy
Colour: Black
Dimensions
