Sammy LE32R41BDX fault?
gazzawesty
I recieved one of the above today and when i power the set on the menu appears for about 2 seconds then the screen goes blank. If i turn the set off, then on again i get a picture for 2 seconds then back to the blank screen. If im quick during thoes 2 seconds i can change channel and see a picture or even put the menu up but no matter what i do the screen goes blank. I connected a DVD player through RGB and the same thing happens, although i can hear the sound no probs.
Ive been saving ages for this LCD and now i have this problem. I thought i would have been playing Pro evo by now.
Anyone any ideas??
Ta
chriszzzzzz
Thats not right!! Send it back and get another one. It will be worth it believe me.
gazzawesty
Yea, i thought so. To be fair Waratah have been really good. They are going to send out another when stocks arrive(Mon or Wed) and do a straight swap. Apart from getting a faulty TV, they have been great on the phone with advise and they ring back when they say.
I just hope they dont take long in getting stock.
Thanks for the second opinions guys.
Trending threads
