Sammy LE23R88 shiny screen? To many reflections?
Discussion in 'LCD & LED LCD TVs Forum' started by Garry123, May 28, 2008.
Tags:
  1. Garry123
    Garry123
    Feb 6, 2006
    2,100
    +239
    I was thinking of buying this for the conservatory but i'm worried that there will be to many reflections from the screen. Has anyone got one so they can tell me what its like?
    I was originally getting a Sony 26t3000.
  2. Yemeth
    Yemeth
    Jun 5, 2007
    5,102
    Hedeby Island
    +993
    The screen is matte, like most other lcds. So no reflections. The only reflections you'll get is from the piano black bezel. I have a 37" version btw.
  3. Garry123
    Garry123
    Feb 6, 2006
    2,100
    +239
    Cheers. Sammies always look shiny in the shops. Like you say it's just the bezel. Cheers for that. The sammy it is then.
