ActualWinners
Established Member
- Joined
- Mar 6, 2006
- Messages
- 187
- Reaction score
- 7
- Points
- 64
Hi folks,
I'm changing my TV and have narrowed my selection down to one of the following:
Samsung LE40A556/7/8/9 (What's the deal with the last digit?)
Sony KDL-40V3000
Toshiba 46XF355DB
The Tosh is the 46" version because it's physical size due to the thin bezel makes it barely any bigger physically than the other two. Pllus it's only £800 at Comet!
Anyway, what would you recommend? I really want the Sony (even though it's an old model) but having seen it up against the Toshiba and Samsung in Comet, I didn't rate the PQ too highly but I guess this could be down to setup? Having said that, even in my local Sony Centre, it didn't impress me.
Maybe there are other choices I'm overlooking in the £600 - £800 price range...
Main uses will be SD TV via Sky+ (possibly with move to Sky HD soon), gaming and BluRay with the PS3. PC connected via RGB D-Sub or DVI>HDMI @ probably 1280x720 or 1366x768.
Thanks in advance!
Sony KDL-40V3000
Toshiba 46XF355DB
Thanks in advance!
