Same Size, Same Manufacturer but Which Model?
Discussion in 'General TV Discussions Forum' started by firlandsfarm, Feb 1, 2004.
  1. firlandsfarm
    firlandsfarm
    Let's assume I have decided on a 36" CRT and that I like the picture provided by the Philips sets (but it could be Tosh. or another). What's the difference between the different models with same screen sizes from the same manufacturer?
    I expect I will want to upgrade to seperates in about a year so do not want to spend a lot of money on good internal tuner/amplifier components for them to become redundant when I introduce the seperates. Will the more expensive set be worth the extra in required components for a seperates set-up or will the extra money be wasted in a years time?
    David Caple
  2. Contar
    Contar
    Mar 2, 2003
    105
    Near London on the M1
    The usual diffrences are Standard set, Set with a digital tuner, set with dolby digital & extra speakers. I am sure there are many other diffrences if you look. Go to the manufacturers websites or a supplier and look at them.
    2nd If you are gonna upgrade then get the best screen without the bells and whistles. You will be adding them next year. :smashin:
