Same Amp-feeding 2 rooms?
Discussion in 'Home Cinema Speakers' started by b crowden, Mar 1, 2003.
  1. b crowden
    b crowden
    Hi All, im looking for help connecting up a Marantz Sr4200. I want the option of be able to use the amp in 2 rooms but not at same time. i.e i want full surround options in both rooms. im not sure if connecting up duplicate speakers would damage amp output especially the subwoofer o/p.
    Any suggestions would be great, the reason for this is i will be locating all my a/v equipment centrally.
    Also I am looking for decent flat speakers for walls and ceiling speakers for stereo sound upstairs. Any comments reviews??
    Many Thanks
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    You would have to use an external speaker switch unit, but i don't know if it even excist such a switcher.
    But whatever you do, do NOT drive 2 pair of speakers in all channels at once, your amp will not handle that load.
  3. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    my sony TA-FB740R 2ch amp handles my load of about 2ohms at quite high volumes without a problem. but does get alittle hot...
    I dont think this is healthy... but I like powering 3 pairs of speakers at the same time... :clap:
    (ps I have pair of Tannoy R2 in main room[6ohm], Wharfedale Valdus 400's[8ohm] in Conservatory and a pair of Acoustic Energy Aegis 2[8ohm] in the kitchen....)
    The amp has speaker A/B so, the Tannoys and Acoustics run A/B respectively. And I have speaker switcher unit in "A" for the Wharfedales)
  4. nathan_silly
    nathan_silly
    Put three pairs of Martin Logans to your Sony, and see the Sony melt!
  5. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    If I'm reading you right ... you want a set of all 5 speakers in each room.
    In this case you'll have to buy 3 2-channel switched (I've never seen a 6 channell switch) plug a 2-way input expander to switch the two subs. Try to get the type that only allows you to sellect A or B, not the one that allows you to select A and B at the same time as it will put strain on your amp.
    When you want room A ... set all four switches (3x speaker plus input expander) to A, when you want room B ... set them all to B.
    Okay so this isn't the most elegant solution, but it will work.
    Hope this helps
    Vikki
