sam m87 or sony w2000 have until tonight and which are the best panels
crashuk
need help with the two, which would people recommend and what are the best panels? sam m87 £820 3 years or sony w2000 5 years £940.
need help.
ChrisGgr
You must order tonight?Anyway these are the best 40" 1080p!!So as a sony fan I will suggest you the W2000!!Simply be careful with the clouding!!!
crashuk
what panels should i be looking for ?
well i have until tomorrow if i wanna use the 10% off code for the sammy.
badbob
Sony 2000 panel is previous gen, Samsung is newer. Although Sony has Bravia engine, but if your sources are 1080p then Bravia engine is bypassed.
crashuk
some said look for a sticker at the back of the lcd for the panel makers, as there were 3, thats what i need to know which one was teh best.
ChrisGgr
The S is the best you should be looking for(The A is good too)
