We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Salvaging an iPod Hard Drive
Discussion in 'Headphones, Earphones & Portable Music' started by nadface, Oct 23, 2005.
Tags:
  1. nadface
    nadface
    Jun 16, 2005
    98
    +7
    Hola!
    My mates 4G 20GB has gone bust. Presuming that the Hard Drive is all okay is there any way of salvaging the data on it? Either taking the hard drive out and connecting it up to my PC (how?) then mounting it as an iPod and using Copy Pod to retrieve the music collection, or any other ideas?
    Oh, and if my iPod mini is of any use in concucting a solution then it's a viable option!
    Cheers!
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    The interface is a CF-type IDE interface, but CF readers (even Microdrive-safe ones) will burn out by the current required for the 1.8" HDD drive.
    All I can suggest is a CF IDE->regular IDE pin converter. I haven't seen such a thing though... If you mount it this way, then since it's FAT32 formatted (if you initialised the iPod on a PC) you should be able to read the disc.
    If you can't get programs like Copypod to recognise the IDE-mounted iPod drive, it's probably easier to just copy the hidden iPod_Control music folders off, then use a mass tag-based renamer to rebuild the filenames.
  3. nadface
    nadface
    Jun 16, 2005
    98
    +7
    Cheers!
    Would there be any hardware conflicts with sticking the HD in another iPod of the same model to retrieve the data?
    Ta!
  4. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    Not to my knowledge. BTW, buy a guitar pick if you don't have an iPod specific tool which some 3rd party battery manufacturers supply.
