Saitek AV selector for Xbox
Discussion in 'Xbox Forums' started by astonbilla, May 8, 2003.
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Anyone seen this yet? seems pretty neat and cheap at £20
    My Quattro has packed in, any info would be grand thanks
    Bill
  2. NeoBlade
    NeoBlade
    Is it an RGB or component selector? I've never heard of it as I'm quite happy for my Argos one (RGB compatible and £9.95) to handle my RGB duties while I have another swtichbox for all my progressive scan needs (PS2, Xbox, Gamecube, DVD player).
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Is that the one that looks like an Xbox or one for the Xbox?
  4. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    sorry guys i didn't make myself clear, i was at a training course and had to type fast before getting caught skiving!!
    It seems to be a generic swtich box that takes scart in. It has 4 push buttons on the front to select the preferred device, and apparently doesn't lose quality etc
    Click here
    I'm wondering though if its RGB or not??
    Won't know unless i buy it i suppose. 20 quid ain't too bad i suppose.
    Neo, which scart box do you have - there are 2 on the argos site, is there really no image quality loss? i would feel like a right tit if i forked out 80 notes for a quattro if a tenner would have sufficed.
  5. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Neo,
    What is the component switchbox that you are using?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    I use a JVC passive switch from Dixons £15 4 inputs to one gold plated scart lead about 0.3m takes 4 RGB inputs, great only a problem when more than 1 input is live.
  7. pingtuk
    pingtuk
    Feb 5, 2003
    76
    I have this and it works fine and I can't really notice any quality lost.
    However, its not RGB or even indeed Scart. It uses S-Video and composite. I used it for switching the S-Video between my GC and PS2 but now I don't use it anymore since I have a Sony 1080 receiver to video switch.
  8. NeoBlade
    NeoBlade
    Right, this is the baby I'm using - Click here to jump to the Argos site
    I am fussy with visuals (after all, I went for progressive scan) and I see no massive loss of detail, if any at all using this Scart splitter. For a tenner you can't argue, plus its Argos so if you don't like it (of which I very much doubt) then just return it.
    As for the component swithbox theres loads out there.. Heres a cheap (£20) manual one. The one I have doesn't seem to be in stock anymore... Its either that or someone has made it stupidly difficult to find.
    This one is quite close, but I don't have the scart sockets Thats usually around £40.
    In fact, this one I believe is the exact one (after loads of searching) - Click here Remote controlled switching and up to 6 inputs so thats plenty.
    Here is another one which seems to be quite decent being automated...
    Can't argue with anyo of them but I'm very happy with the one I've got. Hope that helps mate.
  9. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    :eek: Thanks for all that info Neo, you're a star!!
  10. NeoBlade
    NeoBlade
    No worries mate, always ready to help a fellow gamer and enthusiast ^_^ Thats why I like these forums as everyone is helping each-other out, unlike some other places I've visited...
  11. PardonTheWait
    PardonTheWait
    The hubs you linked to at beststuff.co.uk and keene.co.uk are the same hub, and are also available at maplin (the third link you posted). I've got one, it's certainly decent enough for my modest system.. Couldn't tell you if you can tell the difference with a better tv etc though. My local maplin are currently selling them at half price (£25), I wouldn't know if that would be a nationwide deal or a local one. Most likely local though. (the remote is nice to have.. I mean lose...)
  12. NeoBlade
    NeoBlade
    lol are they? I was too busy frantically searching with multiple windows for it. Ah well, at least its nice to know its freely available. I have a Toshiba Strata, 36" that cost me over £2k when I pre-ordered it and I can't tell the difference using only IXOS cable (60/m) and that switch box. I've yet to try with cheaper/less effective cable though.
    As for that remote, I got rid of it as my Pronto Neo handles everything...
  13. bash
    bash
    Nov 10, 2002
    2,874
    London
    +569
    Ignore/bad post
  14. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Neo matey - got the splitter, works a treat. You're a top bloke!
    Shame i wasted nearly a ton on a quattro last year which is now duff - maybe the boys at beyond hifi can sort me out with something else eh?
    Bill
