Sahara C775 Multimedia Projector Any good
Discussion in 'Projectors, Screens & Video Processors' started by seafoodmix, Sep 1, 2004.
  1. seafoodmix
    seafoodmix
    Nov 13, 2003
    120
    Can anyone tell me if this projector cuts it for £700, what are the things to look for in a projector, is it brightness ?
    XGA (1024*768)
    1300 ANSI lumens
    2.3kg (5.10lbs.)
    1500 hour lamp life (typical)
    System 3 * Polysilicon LCD
    Resolution XGA (1024*768)
    ANSI Lumens 1300
    Contrast 400:1
    Lamp 150w , 1500hrs.(typical)
    Lens Manual zoom/focus
    Interchangeable No
    Image Size 29" - 498" diagonal
    Throw Distance 1.00m - 15.00m
    Computers VGA-XGA
    Video NTSC, PAL, SECAM
    Computer Inputs 15 pin d-sub * 1 ypR/cr
    Pb/Cb RCA * 3
    Video Inputs Composite
    S-video
    HDTV 1080i, 720p
    Audio 2w inbuilt speaker
    Remote Projector only
    Noise 37db.
    Dimensions 277mm(W) * 70mm(H) * 195mm(D)
    Weight 2.3kg
    Power Supply 100-240vAC 50-60Hz
    Warranty 2yrs return to base (90 Days/500 hrs on lamp)
  2. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    What do you want it for?
  3. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    If you want it for home cinema then you could do far better with a little more money. The model you mention has a native 4:3 panel, low contrast (400:1) is a bit on the bright side, and has fairly low lamp-life by comparison with the current crop of home cinema projectors (1500hrs vs. 3000 - 5000hrs).
    I'd suggest you consider spending about a further £3-400 and look, for instance, at the Panasonic AE500 (700 on the way), Hitachi TX100, Sanyo Z2 (Z3 on the way) - any of these models will offer you higher resolution from widescreen panels, far better contrast range and colour performance that a projector designed for the presentation market. There are also a number of DLP projectors on the market in the price range - do a bit of reading here and you'll se what people have to say about them.
    Sean G.
  4. seafoodmix
    seafoodmix
    Nov 13, 2003
    120
    many thanks, i think i will hold off untill i have read up !!
