Sahara AV 3600 Lamp
Discussion in 'Projectors, Screens & Video Processors' started by Klimo, Feb 24, 2005.
  1. Klimo
    Klimo
    Does anyone know if the Sahara AV 3600 lamp is the same as the S3600 lamp? The S3600 lamp seems to be a lot cheaper!! :)
  2. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Probabley the Sahara units are just rebadged manufacturers kit.
    If you see a model and even a manual that is the same, you would be pretty sure it is.
