Sagem vs Themescene
Discussion in 'General TV Discussions Forum' started by Rossbikeking, Mar 14, 2005.
  1. Rossbikeking
    Rossbikeking
    Dec 21, 2004
    11
    Southampton
    Is it worth getting rid of the Sagem hd50 for a themescene rd50 seeing as i want to watch dvd's through the dvi with a denon 2910 with hdcp or am i better off sticking with the sagem.
    Doe's anyone know of any problems big or small with the THEMESCENE i am aware of the region 1 problem and this does'nt bother me.
    Also is the picture alot better with the RD50 ref rainbow/ghosting/colour smudging.
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    The Sagem50 has a much better picture than the sagem 45 but in my opinion the Optoma RD50 is better i have seen the Sagem 50 with DVD's through component in Comets & it was a very good picture but contrast is not as good as the optoma & whites tend to burn out.The hidef demos in Comets looked as good as the Optoma but i don't know if the hidef demos i downloaded have more compression or not.
    see http://www.avforums.com/forums/showpost.php?p=1502012&postcount=59
    for a dealers opinion who has sold both models.
    Also heres a link to a thread i started that has lots of information on the RD50 warts & all.
    http://www.avforums.com/forums/showthread.php?t=178593
    The optoma will give a better picture than the Sagem useing component & you will see a big jump in quality with the HDCP DVI
    Is it worth it ? it depends on how much it is going to cost you remember you
    allready have a good DLP set apart from HDCP and there might be a fix for that in the pipeline.
