sagem sound
Discussion in 'Members DIY Home Cinema Showcases' started by Terry.uk, Mar 14, 2005.
  1. Terry.uk
    Terry.uk
    I am in the process of buying a Sagem Axium but think I will need to improve on the sound.Can you give me any ideas on a budget sound set,blown most of my budget on the TV.I am using a Toshiba SD-201e DVD, will I need to up that as well?
  2. John
    John
    Dec 13, 2002
    10,968
    +2,656
    Terry ,in case you look in , you would be best posting the question in the forums , this is just a Gallery . click the Forums button ,top left
    John
